Posted 8/30/2015 21:08 (#4761766 - in reply to #4761629) Subject: RE: 1st yr Integra yield monitor
Morris, IL
How are you getting these ".5% and "3%" the first year? If you are using entire fields or even the entire farm at elevator that is probably true. But i can assure you if you watched as close as i do with cart scale running next to me all day and elevator quality moisture tester at the farm you start seeing what it can do. I'm still happy, but i'm just saying sometimes ignorance is bliss.
