South Western Ontario, Canada | RESAGRON - 8/16/2015 17:24
looking at a Case 330 vertical-turbo till unit. Anyone have experience with this on Iowa soils? Corn on corn. Thanks!
What tractor are you going to use? Only ask because if you plan on using an older tractor that doesn't put out 2750psi in the hydraulics you will NOT LIKE the 335. Will not lift it worth beans! Case dropped the ball and undersized the main lift cylinders which won't lift on lower psi tractors when folded.
As for the 330......other than the junk tires from factory we NEVER had a single problem with three units. Sharpen the blade twice a year, grease and drive forward. AND older tractors can lift them!
We sold the cultivator and disc and ONLY use the 330 for 6 years now. Work the stalks in the fall and twice in the spring and plant. |
