roaming | Farmer 4 ever - 5/27/2015 14:41
You were right about this PVK but my rep finnaly came with an answer today and apparently I must set the value to the maximum and not the minimum. My value was 15.5 so I'll check if at max value I still see the same problem even though it doesn't really make sense to me...
What??? Setting your Minimum Turn Radius to the maximum value will force very very wide turns, probably unusable in most situations where you actually need curves. |
