Posted 4/26/2015 19:54 (#4539481 - in reply to #4539457) Subject: RE: Manure tank size for JD 8R
Bernard, IA
If you are flat you could handle 9500 gallons. I would want as much hp as possible. I forgot to mention our 8430 on the 7300 gallon tank is putting out 360 hp and a little more wouldn't hurt but that's just to pull steep hills. No matter if it's a 7300 or 9500 I wouldn't run it without duals. Also make sure your tank brakes work and TURN OFF THE TANK STEERING GOING DOWN THE ROAD!
