Posted 6/11/2014 13:33 (#3913646 - in reply to #3913365) Subject: RE: Best way to remove these bolts (Pics)
just a tish NE of central ND
Well if you could get at it with a camera, Id try a welder as it is still going to be easier than a drill trying to get those out.Weld a washer and then a nut using a lot of heat and let it cool. Then try it. You don't have much to loose.
