Posted 5/3/2014 20:16 (#3852058 - in reply to #3851770) Subject: RE: Hypro hyd pump..oil leak..repairable?
Eastern ND
Get a new one. Then get a repair kit for that one and keep for a spare. Also, just wondering when You turn off that pump, do You put the tractor hyd into float? Or do You just stop the pump dead? If not going into float, that may be part of the cause of the leak. Very high pressure on that motor to stop it from 400+- rpm to zero. Put in float and it coasts down to zero.
