WPFarm - 4/25/2014 08:33
Red/Green - 4/25/2014 06:11
I used power beyond on 2 different tractors to run vac on Deere planters and needed it to prevent pressure spikes when raising and lowering the planter.
How does using the a load sense line on the Power Beyond prevent spikes? A load sense pump supply flow until the highest pressure demand is met. i.e. if it takes 3000 psi to raise the planter, then all circuits will see 3000 psi while the planter is being raised. Once the planter reaches it's final position, the pressure will return to whatever has the highest demand. This is of course assuming that there is only one pump in the system.
