Kenton, Ohio | cutting beans or shelling corn with variety locater enabled with the overlap control on it will not start recording after I pick the head up on the end and turn around and put it back down. shut the overlap control off and it works great. deere has told me its a known problem but can't seem to get it fixed other than upgrade to the 2630. normally I will start shelling into the field after turning around and then the monitor beeps at me and tells me grain is being processed without being recorded.....which obviously messes up the total bushels for the field because it isn't recording
