| Looks like a good tractor reaction arms and wheel seals need to be checked. I would pull the plugs on the front idlers and check the oil as well we have had a few races spin in the hub. SCVs are going to need the update.
Overall that tractor will run for a long time with what you're going to do with it I wouldn't be too worried about weight we run 835s with no weights on bigger equipment than that.
I have an 855 that is warmed up a little more than that with a full rack on the front and front idlers and I still can't get the power to the ground at times. My tracks are worn some though | |
