| Submit a support ticket to PP. They are very responsive.
I had a similar issue with a 1250 planter and Gen2 SRM system, which was wired to use the toolbar potentiometer as the lift switch for the 20/20. Precision said that was not correct because the voltage was too low from the toolbar sensor. They had me disconnect the potentiometer from the 20/20 and install 2 push button lift switches. It worked great after that.
Edited by chris dds 5/17/2021 10:24
