Clinton County, Michigan | MojoRTK used radios from Digi, and although they are FHSS, 900MHz radios of different brands often use different protocols to communicate over the air. So unfortunately, I don't think there is a way to simply change settings and have them communicate.
Since your base radio is external already, you could replace it with a Digi radio, and that would talk to the Mojo. Freewaves are still sold too, so if you have a way to cable in a DB9 serial for external radio on the rover.
Also the GeoAce usually comes with a Digi built in. If that still works correctly, you should be able to get it configured, and just not use the External radio option. | |
