South Central North Dakota | I have a Fmx that is having issues. Some times it will acquire Range point convergence within 5 min, some times it never does but will give me guidance if I go to set up and select autonomous (WAAS) then abruptly I loose all satellites and position. A friend thinks the antennae is bad, any way to check it?. It will do this while setting in the middle of an open field. |
