NE Arkansas | I am wondering if all 8010 hydrostats are the same? I have an 04 8010 that was built a 2wd. It was converted to 4wd later. Everything has worked good. I got a set of grip tracks for tough conditions and it works well unless I need the 4wd with the tracks. In 3rd gear it will run just over 4mph. I think 3rd gear with 4wd "off" on tires is about 12mph so is it just putting too much oil to the back? After a couple hours the charge pressure will start to drop. If I shut the 4wd off it is back good. When running tires I can run the 4wd all day and nothing shows up. Any help would be appreciated or if anyone would know of a dealer or mechanic who has dealt with this specific issue that I could call. | |
