| I have a hairline leak on the weld where the fitting was welded to the tank. I've tried JB weld a couple times, mind you I didn't drain the tank, and it still leaks.
Now, I drained the oil and took the tank off and its sitting on my work bench.
Can I weld it with a mig? Is it dangerous?
JB weld again?
Braze it ?
If I mig or braze, should I fill water? If so, do I need to expel 100% of the water from the reservoir before re-installing?
Thanks | |
