Walnut Grove MN USA | I had that problem but mine would shut down anywhere from a split second to 5 minutes. I was convinced it was a rowflow issue and threw a bunch of parts at it. PP experts said I didn’t have enough voltage which was confirmed running a health check. Added a heavy line direct from batteries along with new batteries in tractor and it still did it. Turned out it was the remote on the tractor causing the issue. Switched to a different one and now everything works like it should. | |
