Southwestern Ontario | We have the same connector, used cable clamps and ran it along the edge of the roof, down the right rear pillar and in through the rear window rubber grommet. I made it neat enough that you can't tell it's there unless I showed you. There was lots extra so I then ran it up under the right console trim (this is on an 8210) and just have enough sticking out the front of the console to plug into the planter monitor. Not too familiar with the 6R interior but I'm sure something similar could be done. | |
