LGR - 5/4/2021 21:49
I am getting low gauge wheel alarm frequently. Using Incommand set on medium setting. Is this normal? Down force will get up to 300# at times. How do I determine ground contact of gauge wheels? Thanks
this year it is quite common. LOTS of comments on here about guys not being able to get planters in the ground with way more than 300 pounds. Set it to the higher setting and increase your time to alarm setting so you don't have to hear the beeping. It is most likely going to have a tough time in these dry soils. |
