Butterfield, MN | I'm not familiar with the spray mate, but AccuBoom sends out a 12 volt signal to activate sections to turn on. Most times boom section valves or clutches can be made to work this way, but in your case you'd have to verify that the spray mate can receive a 12 volt signal in to tell it that a section is turning on so the rate control will apply correctly. Otherwise, if you have all of your sections on for the rate controller but have AccuBoom shutting sections off, it's going to majorly overapply on the sections that are still applying, or flip flop that and have the rate controller not recognize that sections are turning on and only be applying enough product for less than the full application width.
Edited by Amc4life 5/3/2021 13:42
