| I want to hook up an accuboom node and a cruzer 2 to a pull tyoe sprayer but can’t seem to find the application drawings that fit my situation.
First of all, would the accuboom node stay in the tractor or stay on the sprayer? I currently run an accurow, would the accuboom be very similar? The accurow node stays on the planter.
can the node get power from only a can connection or does it need to be hooked to a battery? The application drawing that fits my situation best looks like everything for the accuboom is just hooked into a can connection in the console cable?
I have a chassis cable that runs the accurow when using accurow, but cant find a similar application drawings for accuboom that incorporates a chassis cable like the accurow does?
It would seem i should be able to use the chassis cable with accuboom, or is this incorrect? | |
