What are you guys using to lube chains on a JD planter? I have tried JD all purpose lubricant and also the semi-synthetic lube, but they both seem to attract too much dirt. Everytime I check the chains, there will be dirt sticking to the side plates. This surely isn't good for the rollers! Is there a chain lube that will not attract so much dirt? Thanks in advance!
