Brookston, IN | I have done it w different ways. 1- set A drive with the planter raised to the other end and set B. This is how I do it most of the time. 2 - set A plant one pass around the other 3 sides of the field using the marker for end rows and set B when around to that corner of the field. Turn around and follow marker for second pass of end row. Use auto steer back to other end the plant second pass of that end row.
If you get a good line set you can reuse it in the following years, that makes things easier. | |
