| Use the export screen in the Pro700 to export as ISOXML. Select All data types, but you can still filter the Grower, Farm and Field info. It will take a few minutes to convert and send to the USB. When done, the ISOXML files will be in a folder called EXPORT on the usb.
Insert the usb into the Pro1200, then go to Data > Import. Select Usb as the source, then select the folder called EXPORT.
Pro1200 uses ISOXML data only. By the sounds of it, you may have imported data from the TaskData folder on your usb, which won’t include AB lines, since they’re in the .cn1 folder.
This info is in the Precision Farming Software Guide for the Pro1200. | |
