Im trying to figure out a way of mounting a work switch on my 2210 Cultivator. I tried one of the BEI Duncan Pots but no luck. I think it works on the drill because of the gray box reading voltage maybe? Just plugging it into work switch off back of tractor doesnt come up with the same result. So I wondered if anyone else has done this so they can map with the cultivator? Also want to do Turbo Till and Chisel Plow and maybe Disc Ripper. Any help would be great. I also happened to purchase some threaded rod with ball jointy ends for it. But not sure if the idea will come to fruition. The Big Man
