 South Central ND | When cleaning out a flash drive you first want to go to file explorer>data card>right click on it once data card is selected> select format> use whatever format is specified fat32 or fat is usually the file format I use for the flash drive and select quick format when formatting. This should help with the exporting process. If you have any other Questions regarding SMS I'd be happy to help.
Best of luck,
Rilo | |
