| After researching this problem extensively I came across a post on combine forum that said the planter clutches are activated if the planter was up. Got me wondering about my implement jumper. I had a new one in a box and decided to give it a try. Went to pull the old one out of the CCM module and noticed it wasn’t all the way in and the lock was broke. Put in the new one all the way and now everything works as it should. Wow! How one little wire can cause so much hair pulling agony.
Thanks for the help Tedbear!! Your suggestions pointed me in the direction to fix the problem. Along with a lot of your other post. Really helped me to understand the system and how to troubleshoot when problems arise. Your insight is priceless!! Thank you.
(E217ED10-5D4C-45E8-833F-AA1E9D10FD7C (full).jpeg)
Attachments ---------------- E217ED10-5D4C-45E8-833F-AA1E9D10FD7C (full).jpeg (81KB - 94 downloads)
