Search Forums | Classifieds (49) | Skins | Language
Control more than 4 sections or 8 clutch pairs on Kinze 3605?
Minuteman Farmer
Posted 4/7/2021 17:56 (#8938472)
Subject: Control more than 4 sections or 8 clutch pairs on Kinze 3605?
Kinze 3605 mechanical drive, ag leader clutches, isobus monitored and controlled by 2630.
Clutches are paired together. Anyway to control all 16 individually?
Also, on Kinze planter screen it shows all 16 rows, and 4 sections. So the way its set up if turn off section control and wanted to manually turn a section on/of, you can only do sets of 4.
Problem is that if you have planting issue and need to back up to replant a row that wasnt planting, the best you can do is turn off 12 of 16 rows. So end up double planting 3 rows if your just trying to replant 1 row that screwed up.
Any way to change this or do something else in the 2630 when this happens?
Thanks!
