 SW Iowa | Has anyone else had this JD Rate Controller warning screen? This is on a pull type sprayer with
5 sections. It came up several times while doing a test run. Every thing is functioning correctly until the warning screen comes up.
When that happens, all sections shut down. Cycle the master switch and everything works again, for a bit.
We've checked the wiring harness and can find no damage. And all the connections appear in good shape. Any ideas?
Thanks Rick
(IMG_1931001 (full).jpg)
Attachments ----------------
IMG_1931001 (full).jpg (149KB - 2 downloads)
