GFX750-Nav900 in 4440-best place to put display?
Farmhand89
Posted 4/6/2021 21:08 (#8937128)
Subject: GFX750-Nav900 in 4440-best place to put display?
South Central Wisconsin
Putting GFX750 in JD4440 to run EZ Pilot and Nav 900. Have three questions. (actually 4)
1.) Anyone have advice as to where to conveniently mount the Display? I had my EZ Guide 500 straight in front of the steering wheel, but I never touched it while operating(used a toggle switch for coverage on/off). I'm thinking fairly close, as it seems like I will need to tap it every time to engage autosteer.
2.)Any suggestions on mounting the Nav 900 to the top of the cab. reluctant to use the "sticky tape" provided.
3.)How anal should I be with cable routing, should I try to go thru the roof? (EZ guide cable just ran thru the lower window on the right side)
4.)Am I crazy for sticking this much $$ in an old tractor?
Thanks in advance for your wisdom!
