Search Forums | Classifieds (1) | Skins | Language
Morninglory in corn, post
neiowa
Posted 4/6/2021 06:46 (#8935991 - in reply to #8935191)
Subject: RE: Morninglory in corn, post
had good luck with glyphosate killing it. Peak works good on morninglories but not an option if you want to rotate out of corn. A high rate of atrazine is probably the best residual option here. What I have seen works the best is spray early post then again just before canopy in corn. Also a soybean rotation helps a lot since you can make a glyphosate pass later in the year to get them
