NE CO | Importing the new boundaries will overwrite all the current boundaries. Unless you are running the newest 21-1 software in which it is a little different and you can now have multiple boundaries per field and choose the one you want to use, deselect it entirely, etc. With new software a new boundary will not become the active boundary for that field, you'll need to manually select the new one as active.
Deleting things from a Gen4 is rather cumbersome unfortunately. For boundaries you'll have to go through and delete them one by one. Or if you are loading fresh info, usually the best thing to do is go into Fields and Boundaries then Manage, then just delete everything there, clients, farms, fields, then load your new info. | |
