Search Forums | Classifieds (163) | Skins | Language
Tornapart 9560RT steering redundancy update
KT1
Posted 3/3/2021 13:26 (#8870521)
Subject: Tornapart 9560RT steering redundancy update
SE Iowa
Tornapart,
I replaced the cross shaft speed sensors and deleted all the steering codes and the tractor is still acting the same (twitching at startup, shooting codes, and then acting fine after shutdown and restarting). In the last post you mentioned the EDC Null Adjustment and the 4 step T Valve calibration. Is this still what you recommend? Is it something I can do or does the dealer need to? Thanks again for your help.
