Posted 3/3/2021 08:34 (#8869901 - in reply to #8869856) Subject: RE: 12/23 1200 on 7140 Magnum
There is a case drain kit for the tractor . At that it has some back pressure . I drilled and tapped into the rear housing . Or dump into fill pipe . If you use ends be sure and take balls n springs out . So if it comes unplugged it will still drain .
