Walnut Grove MN USA | Have had both, without a doubt bar behind cart. Can back into a corner where that is more difficult with a pull behind cart, goes around a curve better, less stress on tractor hitch turning on the ends. It’s not all roses though, you usually have to listen to a fan and visibility of the rows behind cart is nonexistent. Also need to consider the tender when filling, sometimes certain configurations won’t work to well. | |
