Posted 3/1/2021 19:14 (#8866618 - in reply to #8866481) Subject: RE: tapping into deere 1770nt air tank to run air clutches?
Yes this will work but you need a regulator set to 90 psi. You may use the line from the compressor to the tank. I would also put the compressor filter in the cab to prolong the compressor life. This will work the compressor almost to its limit trying to keep up with 16 rows.
