Central IL | Putting a Trimble WM Drain system on a Speicher wheeled machine and my choices to select a valve module are PT, PWM or Proportional. Is this any of these? It appears the valve controls a cylinder that will push the cylinder up, but then gravity is how it goes down. I am no hydraulic expert so my terminology is probably not correct. TIA and also on the same subject, where would be the best place to build the mast to put the antenna? I have an idea of where but just looking for other ideas or input.
TIA
(PXL_20210211_162839612 (full).jpg)
(PXL_20210211_162844752 (full).jpg)
(PXL_20210211_162908516 (full).jpg)
(PXL_20210211_162917712 (full).jpg)
(PXL_20210211_163955649 (full).jpg)
Attachments ---------------- PXL_20210211_162839612 (full).jpg (119KB - 126 downloads) PXL_20210211_162844752 (full).jpg (87KB - 119 downloads) PXL_20210211_162908516 (full).jpg (119KB - 126 downloads) PXL_20210211_162917712 (full).jpg (112KB - 127 downloads) PXL_20210211_163955649 (full).jpg (126KB - 128 downloads)
