Sunnyvale, CA | On the EZ-Guide 500 wrench > (assuming Advanced settings) System > GPS > GPS Setup > Ext. Corrections > 38400 No parity 1 stop bit.
On the Ag132 set up the serial port (A or B) to RTCME at the same baud as the 500 (Configuration > PPort A Config > I none 38.4 8N1 O RTCME 38.4. Make sure the Ag132 is tracking the beacon station you want. Plug in cable 30945 from the Ag132 into the EZ-Guide 500 9-pin connector. | |
