Posted 4/25/2009 23:19 (#692863 - in reply to #692616) Subject: RE: still having ez steer problems
you have no DGPS correction signal. what are you using for your power source. If you're using the lighter plug replace it with 63193 plug and wire it direct and it should solve your issues. it sounds like the system lost its ground coonectionand is trying to reset itself. unplug and plug it again to see if that helps.
