| are you 0 to 8" on direction then when you turn around you are out 1'6" the oppisite direction.if this is happening what ive do that works is go into your 500 and either change the satalite setting from auto select to wass 138 only.up here in canada we find sometimes this works and usualy if your going in a east to west direction.when your going in a north to south direction then you can be in the auto select mode.to change modes go to the wrench or config menu, system,gps, then arrow down to when it says auto select and then press o.k an change to wass 138. hope this helps. | |
