Posted 4/25/2009 00:14 (#692130 - in reply to #692072) Subject: Re: help with ezsteer setting on tracks
Sunnyvale, CA
the settings are different with the EZ-Guide 500 driving the EZ-Steer. When the controller was changed to 50 Hz for the EZ-Guide 500 the settings required are different than the settings needed with the EZ-Guide Plus. With the EZ-Guide 500, then first thing to use is the Calibration wizard. That should get you pretty close to optimum.
