Everything is done now so here are the pics. First pic is the clutches, nothing special here. The tank and air module setup. For an implement switch we used the one for the smartbox which is located to the left on the first wheel. We don't use the smartbox anymore so that is why we used this switch. After running the compressor for a while there seemed to be some heat buildup in the box so we mounted it outside. Here are the wires going to the tractor. All of the wires which the driver can't see. And finally, the cab. I built a bracket which goes across the right window which really worked out very nice. A powerstrip purchased at our local Deere dealer powers everything and is connected directly to the battery and is tuned on and off by a switch. More wires. And the entire setup sitting in the shop waiting to run.
