Kansas | Go to JD Operations Center, then Stellar Support. There you can download the latest software, save it to the memory card. There are instructions also in Stellar Support as to how to do all of the steps.
You can hook the 6000 up on the machine that has the 2600 and it will tell you what version of software it has. Go to the globe button and it will tell you what version of software it has. The 6000 should be version 4.40P.0
The 3000 version should be 2.8s if I remember correctly. Good luck!
If the 6000 doesn't have the right software, you can download the updated version to a memory stick and then you plug it into the bottom of the 6000 globe. There is a round plastic nut that you take off and the usb port is under the nut. | |
