| You may want to try reducing the precision of the NMEA output on the Ez-Guide. Many controllers will not accept the number of decimals that the Trimble outputs when on RTK. The GS2 requires it to be no more than 6 decimal places, and i would imagine the falcon is similar. This is in the system setup of the EZ Guide. Also check to see that the proper NMEA messages are being outputted to the Falcon, but since it is working on WAAS this is probably not the case | |
