Posted 1/7/2021 16:43 (#8731426 - in reply to #8731237) Subject: RE: 6.6 cat motor overhaul kit
I will check it out. If it was the same one I seen it was was only 400 dollars cheaper than than cat wanted. If I am going to get raped might as well let cat do it. I just thought four thousand dollars was a bit much. But thanks for the info
