nc ia | You will be dealing with 45-48000#. If it can be hooked to monitor, you can lower it into storage mode, which will bring height down several feet. Also when backing and going forward the tires caster around a lot. Very tricky to put on trailer. When I bought mind, dealer from 60 miles away, said to come get it with my tractor. It wasn't that big of deal. He followed me half way and stopped to re-torque wheel bolts and check for bearing heat. All was fine so I went the rest of the way home . | |
