Clinton Minnesota | Both models perform the same. The changes are in the frame and auger. They went from driving the auger from both ends on the larger heads to just driving from one end on the 12 and newer. The poly on end snouts are different the changes are mostly cosmetic. Both deck plates move on 12 and newer and gear boxes are setup so you can change all the snap roller seals without taking off front cover of gear box. | |
