northeast mo. | i have a old ih 3964 track hoe, with a bad motor . rod bearings out crank bad. just went out this afternoon, pulled the pan off lots of bearing in the bottom of pan. for those of you that know about ih motors would a 414 out of a 1460 have the same bell housing bolt pattern . all that drives the hole hoe is the hyd. pump off the damper on the front of the motor, but would like to have a motor that will stil work with the bell housing of the hoe. thank you. | |
