ne MD | FARMEX or AGRATRONIX makes one. It is model number 1210. Amazon sells it. We have one. Ours came from Kooima, they may still sell it. You have to put the silage sample in a small zip lock bag to use it for silage. You have to use a new bag for every silage test. You have to check the silage temperature too. It does include a thermometer, but I just use a infrared thermometer. I just use it in the field to check the moisture. It will also test grains, but does not require a bag for dry samples. I still use Koster testers to check moistures at the farm. | |
