West TN | I looked at some Kubota literature that I have and aux hyd flow rate on the SLV-95 is std 23.1 gpm and high flow rate is 40 gpm. The SLV-75 std flow rate is 17.4 gpm and high flow rate not available on this machine. I would check hyd requirements on any mower you might want to put on the SLV-75. The operating weight on the 75 is 9300 lbs and the 95 is 11,500 lbs. HP on SLV-75 is 74 and 95 on the SLV-95. | |
