Northeastern Pa. | I broke my gps receiver off the first year I had the 9600. I don't map so I didn't replace it. The brown box will let you put in different field #s etc so if you want to keep that info just write it down and reset for the next field. Keeps track of acres too. You can do a lot with it without the gps. The corner post monitor will keep track of acres too and yield but I could never get the yield to work. It would be best to get the Green Star operators manual and a 9600 combine manual. That will help you set everything up. Have fun. You'll really like the 9600. | |
