North Texas Panhandle Dumas Texas | Think about it
Pro germinator weighs 11.2 lbs/gal. If it contains 10 lbs of P or P2O5 then the N, K, and Fe potion is only 1.2 lbs.
Label guarantee is 24% P2O5 which would be 2.69 lbs P2O5.
Ask them to put in writing that it contains 10 lbs per gal.
Also read the derived from portion of the label then research and you will see that there is nothing special about it. |
